VR Hand Tracking for Object Interaction
VR hand tracking for realistic object interactions using WebXR and physics simulation.
< Back to templates
This template demonstrates how you can use hand tracking in VR to pick up and drop objects. It uses the Physics and WebXR packages to create a simple but realistic interactive scene.
Although this project will work with controllers, it's better suited and setup to work with tracked hands. There are 2 Physics Actions setup on the Left / Right controller components respectively. These set the event in which the objects should be grabbed and toggled (dropped).
Both controllers also come with a RigidbodyGrabber. This RigidbodyGrabber allows an entity to grab dynamic rigidbodies to move them around. Only one object can be grabbed at a time per grabber. There are editable properties on the RigidbodyGrabber, so be sure to check that out if you start from this template.
Please note: this is a VR template but will also work with Mixed Reality on supported headsets.
If you'd like to add your own grabbable mesh / 3D model, make sure to add a Physics behavior and set the Grabbable property to true.
Google Chrome
Magic Leap 2
Meta Quest
