![Shader Material Template](https://zap.works/static/img/mattercraft/library/simple_shader.png)
# Shader Material Template
Custom shader materials with independent left/right color controls for unique visual effects.
[Open in Mattercraft](https://app.mattercraft.io/?sb=Custom%20Shader%20Material\&t=shader-simple) [Try now](https://webxr.run/E2LXYRMWp9WnQ) Try now
This example demonstrates the power of custom shader materials. The shader splits the UV coordinates in half, allowing for independent control of the left and right side colors. We've included two observable properties for the left and right colors, enabling adjustments from the material node properties panel.
Please note that while this example is simple, it showcases the possibilities for creating complex visual effects, textures, and animations using shader programming.
As with other templates, this project includes a default splash page - a 'launch' screen shown to the user when they first land on your page. You can customize it in the index.html file to match your project's needs.
Microsoft Edge\
Canonical: https://zap.works/templates/shader-simple/
