# Reflector – Mirror-Like Reflections
A custom Reflector component for adding mirror-like reflections using Three.js.
[Open in Mattercraft](https://app.mattercraft.io/?sb=Custom%20Component%20-%20Reflector\&t=custom-component-reflector) [Try now](https://webxr.run/GlERmxvG8gPaP) Try now
This template showcases how to create a custom component in Mattercraft using an object from the Three.js examples. In this case, we create a Reflector component that acts as a mirror, reflecting a dancing robot in the scene.
The custom Reflector component is built using the Reflector object from the three/examples/jsm/objects/Reflector module. It exposes properties such as textureWidth, textureHeight, clipBias, and multisample that can be adjusted to fine-tune the reflector's appearance and performance.
To use the Reflector component in your own projects, simply copy the component file into your project. You can then add the Reflector component to your scene and adjust its properties as needed.\
Microsoft Edge\
Canonical: https://zap.works/templates/custom-component-reflector/
